Unable to access EDIT mode
Hello!
I'm unable to enter the EDIT mode (https://localhost/EPiServer/CMS) in my solution. An exception is thrown and I can't figure out why. I'm able to access the ADMIN-section (https://localhost/EPiServer/CMS/admin/Default.aspx) Any suggestions what can be the problem?
I'm new to EPiServer so there is a risk of rookie misstakes.
Thanks in advance!
Exception
#140645
Oct 26, 2015 15:51
What happens if you choose a debugger?
If you have performance monitor running when this happens, do you see if the w3wp service takes a lot of memory, cpu or something like that?
#140650
Oct 26, 2015 19:41
That could be anything.. What you do in your start page? Any stackoverflows, asking for content reference of the same content reference? Null reference exceptions.. What about log files? Windows Event log store? You may find some traces there..
#140661
Oct 26, 2015 20:59
Thanks for your help guys, there must have been someting with my IIS that caused the problem, I used another copy of our development environment and it worked as it should.
Thanks!
Oskar
EDIT: A collegue have had the same problem and told me it could occur if Visual Studio 2015 beta had been installed. He had uninstalled it and got it to work again so if anyone experiences the same issue it might help to uninstall VS 2015 Beta. I had it installed on my machine so that might have been the problem for me as well.
#140868
Edited, Nov 02, 2015 14:30
