Strange error on Forms
I have a strange error on the use of Xforms in Episerver 9..
I made a Block which renders a form, so you can implement it in every page in a contentarea. Now all good until now, sadly recently i get a 'bizarre' error:
"CS1061: System.Web.Mvc.HtmlHelper bevat geen definitie voor Translate......"
This means it doesnt contain a function or extensionmethod for 'Translate'. Now that is too bad, but the weird thing is, it refers to the file
'/Util/Views/Shared/DisplayTemplates/XForm.ascx ' and refers to an error on line 8:
Regel 6:  <% if actionresult ="null" actionresult.xformid.tostring="=" model.id.tostring actionresult is episerver.web.mvc.xforms.xformsuccessactionresult regel 7:>
Regel 8:      <%: html.translate xform formposted>
Regel 9:  <% else>
Regel 10:     <% using html.beginxformmodel htmlattributes: new class="form xform">
However, I work strictly with MVC and not webforms, so i'm surprised about this ascx usercontrol and when i look for this file (and even the use of html.translate)  it's nowhere to be found???
How can i solve this?
#140799
Oct 30, 2015 11:02
Had the same problem. Added EPiServer.Shell.Web.Mvc.Html as a global import directive in Web.config.
This needs to be in your main Web.config file and not the one in the Views folder.
It should look something like this:
<configuration>
	<system.web>
		<pages validateRequest="false" enableEventValidation="true" pageParserFilterType="System.Web.Mvc.ViewTypeParserFilter, System.Web.Mvc, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" enableViewState="false">
			<namespaces>
				<add namespace="System.Web.Helpers" />
				<add namespace="System.Web.Mvc" />
				<add namespace="System.Web.Mvc.Ajax" />
				<add namespace="System.Web.Mvc.Html" />
				<add namespace="System.Web.Routing" />
				<add namespace="System.Web.WebPages" />
				<add namespace="EPiServer.Shell.Web.Mvc.Html" /> <!-- This line needs to be added -->
			</namespaces>
		</pages>
	</system.web>
</configuration>
/Jakob
#152295
Aug 23, 2016 13:18
