Service API routes in IIS Express vs IIS
Just noticed: if site is hosted in IIS Express Service API from Commerce package are not registered. When the same site with no code changes hosted in IIS -> all routes are registered.
Latest version of all packages. No "delayed" attribute based routing registration. No custom Owin startup class. Everything defaults.
Any ideas would be much appriciated!
#139929
Oct 10, 2015 11:25
Are you seeing any routes at all?  I am assuming you have enabled the iis express ssl.  Have you made sure the binding is mapped to a certifcate.
netsh http show sslcert > output.txt
I am able to use with iis express fine.
#140229
Oct 13, 2015 22:41
routes get registered after reboot and temp file cleanup. weired anyway..
#140232
Oct 13, 2015 23:10
