I figured it out. The post address on form was generated wrong. I managed to get it right with UrlResolver,
<form action="@UrlResolver.Current.GetUrl(Model.Variation.ContentLink)AddToCart" id="AddToCartForm" method="post">
but now I'm having a new problem .
After Post I try to RedirectToAction, but again 404 Not Found error pops up. It tries to redirect to default address again.
How can I prevent it from redirecting to
http://localhost:44300/ru/kataloog/elektroonika/telefonid/nuti/4jasuuremad/4-ekraaniga-vee--ja-tolmukindel-nutitelefon-caterpillar-cat-b15q_dc9d1a1a/
And instead get the right address
http://localhost:44300/ru/kataloogRU/elektroonikaRU/telefonidRU/nutiRU/4suuremRU/smartfon-s-4-ekranom-vodo--i-pylenepronitsaemyy--caterpillar-cat-b15q_eb02a8d5/
My current Action looks like this.
[HttpPost]
public ActionResult AddToCart(GeneralVariation currentContent, int amount)
VariationLogic variationLogic = new VariationLogic(_contentLoader, currentContent, _marketHelper, _logger);
variationLogic.AddVaritationToCart(amount);
return RedirectToAction("Index", new {node = currentContent.ContentLink});
I'm having trouble with routing when posting form from another language other than default.
For example . I've got this
which generates my post form
which works fine, but when I switch to Russian language for example. Html.BeginForm generates action
Now I tried different routings for this, but nothing changed. I still get 404 not found error.
Should the routing be something like this?
What should I look for or try and change?
Using episerver 9
Regards,
A
