iisexpress.exe has exited with code -1 (0xffffffff)
When am running visual studio in debug mode am getting below error but in release mode its working fine.
ERROR:
iisexpress.exe' has exited with code -1 (0xffffffff)
#140251
Oct 14, 2015 10:51
Strange but that has probably nothing todo with episerver. Most likely it is an issue with you installation or something bad in the project setup. Could you try to create a complete vanilla epi project or asp.net project and try the same. If everything is working with the vanilla epi project then you have something wrong in your project.
You could try to change the portnumner in your project settings to another and run the solution again.
Have a look in this thread at stackoverflow: http://stackoverflow.com/questions/19472682/asp-net-mvc5-iis-express-unable-to-debug-code-not-running
#140326
Oct 15, 2015 23:19
