IContentLoader returns unpublished content
Bit of a noob quesiton.
I have the following in a view used to render my page:
    var contentLoader = EPiServer.ServiceLocation.ServiceLocator.Current.GetInstance();
    var imageBlock = contentLoader.Get(Model.CurrentPage.ImageBlock);
    if (imageBlock != null)
And the following property in my page model:
 [AllowedTypes(new[] { typeof(ImageBlock) })]
 public virtual ContentReference ImageBlock { get; set; }
I add a new, unpublished ImageBlock block to the page, and publish the page. Why does IContentLoader return my unpublished block - shuoldn't it return null?
Or is published status something you need to check for in addition?
Cheers
#139971
Oct 12, 2015 14:25
If your're signed in as an editor you will also see unpublished content.
And yes, you have to check publish status and access rights if you're working against IContentLoader directly.
#140183
Oct 12, 2015 15:53
You would generally filter the content returned from IContentLoader to make sure it's suitable for site visitors. In most projects I work on we'll have a content filtering interface and service like the example below:
using EPiServer.Core;
public interface IContentFilterService
    IEnumerable<T> Filter<T>(IList<T> contentItems) where T : IContent;
    IEnumerable<T> Filter<T>(IList<T> contentItems, bool checkPublished, bool checkAccess) where T : IContent;
using System.Linq;
using EPiServer.Filters;
public class ContentFilterService : IContentFilterService
    private readonly IPublishedStateAssessor publishedStateAssessor;
    public ContentFilterService(IPublishedStateAssessor publishedStateAssessor)
        this.publishedStateAssessor = publishedStateAssessor;
    public IEnumerable<T> Filter<T>(IList<T> contentItems) where T : IContent
        return Filter(contentItems, true, true);
    public IEnumerable<T> Filter<T>(IList<T> contentItems, bool checkPublished, bool checkAccess) where T : IContent
        var list = contentItems.Cast<IContent>().ToList();
        if (checkPublished)
            new FilterPublished(publishedStateAssessor).Filter(list);
        if (checkAccess)
            new FilterAccess().Filter(list);
        return list.Cast<T>();
#140187
Edited, Oct 12, 2015 16:25
Yes, as Johan said, the content returned will depend on the current user's access right.
We have a static class (EPiServer.Filters.FilterForVisitor) which provides some methods to help us quickly filter contents which are not supposed to be shown to current end user.
Regards.
/Q
#140188
Oct 12, 2015 16:26
