Seems there is something wrong with your site settings. Since you cannot get into Admin mode, try looking at the tblSiteDefinition table in the database. Check the SiteUrl column for strange data. On a fresh install it looks something like this: "http://localhost:65004/" You can also check tblHostDefinition for strange data.
Thank you!
For some reason there was two "localhost:XXXX" located in the tblHostDefinition. One with trailing "/" and one without. Removing one of them solved the problem!
I get a weird Error after upgrading to the latest and greatest EPiServer 9.0.3.0.
Port must be a parsable integer between 0 and 65535 or wildcard character
Parameter name: authority
Something seams to be wrong with initialization of XForms. Anybody got an idea what might be wrong?
Full stack trace:
