EPiServer 9 Upgrade - Context is missing in EPiServer.BaseLibrary
I'm using following im my project
EPiServer.BaseLibrary.Context.Current["EPiServer:ContentLanguage"]
but after EPiServer 9 upgrade, i'm getting that "Context" is not available in the "EPiServer.BaseLibrary" any more. So what shall I do ?
#140607
Oct 25, 2015 0:57
BaseLibrary and Implementation assemblies were removed in EPiServer v9. Use:
EPiServer.Globalization.ContentLanguage.Instance.PreferredCulture
#140608
Oct 25, 2015 8:17
Valdis, if i want to change the ContentLanguage, if I set it as follow,is it correct ?
var culture = new CultureInfo("no");
ContentLanguage.PreferredCulture = culture;
#140616
Oct 26, 2015 7:48
I would be cautious with this.. What is usage scenario for you? Why you are changing content language? Are you switching to different language in the site or need to fetch content in different langauge?
#140620
Oct 26, 2015 9:25
I'm using this code in a situation where switching to different language in the site
There is a possibility of setting it is as
ContentLanguage.Instance.SetCulture("no");
but i'm not sure which one to use
#140627
Edited, Oct 26, 2015 11:13
