To answer your question, yes you should be able to retrieve the view data.
For instance, given a ContentArea named RightColumnArea and an additional view data with a string named "Placement":
@Html.PropertyFor(m => m.CurrentPage.RightColumnArea, new {Placement = "RightColumn"})
And in your block controller:
public override ActionResult Index(SomeBlock currentBlock)
var placement = ControllerContext.ParentActionViewContext.ViewData["Placement"] as string ?? String.Empty;
string viewName;
switch (placement)
case "RightColumn":
viewName = "RightColumn";
break;
default:
viewName = "Index";
break;
return PartialView(viewName, currentBlock);
That being said, there are other ways to achieve this.
If a block doesn't need any logic it should not have a controller due to performance, if this is your case then have a look at the TemplateCoordinator in AlloyTech.
If you need a controller, you could take a look at the TemplateDescriptor attribute.
Both the TemplateCoordinator class and TemplateDescriptor attribute uses something called Tag, which also makes selecting different views view DisplayOptions possible.
Thanks I'm already using the TemplateCoordinator for rendering our standard page partials and display options for the different adaptive versions of the blocks. This requirements comes from a necessity to be able to adapt the blocks furthur for dynamic resizing information which needs to be applied through from the view dependant on when the block is used which the additonalViewData seemed perfect for. I'll try your approach and see if it does the job.
Thank you for the help
The XML comments for the @Html.PropertyFor says that the anonymous object you pass get's merged in to the ViewData dictionary. I tried passing my own object in to this parameter hoping it would be in my controller in the ViewData collection but nothing is there. Is there anyway to get this data back out again as I need to pass an object through to the block controller to change how it renders for the different places it's used?
