Access attribute for Blocks
I'm trying to set the Access attribute for a block, so only a specific group is able to create that block (rather than the default "Everyone"). I'm following the info here:
http://world.episerver.com/documentation/Items/Developers-Guide/EPiServer-CMS/8/Content/Attributes/
http://world.episerver.com/documentation/Class-library/?documentId=cms/9/CD41BF37
The block is still being created with the default "Everyone" access. Am I missing something?
Sample code:
namespace cms.Models.Blocks
    [ContentType(DisplayName = "PageTitleBlock", GUID = "623351a8-55c0-4f9f-af08-18a1ffe9ba0f", Description = "")]
    [Access(Roles = "BlockCreators")]
    public class PageTitleBlock : BlockData
        [UIHint(UIHint.Image)]
        [Display(
            Name = "Image",
            Description = "Background image for banner",
            Order = 1)]
        public virtual ContentReference Image { get; set; }
        [CultureSpecific]
        [Display(
            Name = "Title",
            Description = "Page Title",
            Order = 2)]
        public virtual String Title { get; set; }
        [CultureSpecific]
        [Display(
            Name = "Subtitle",
            Description = "Page subtitle",
            Order = 3)]
        public virtual String Subtitle { get; set; }
#139860
Oct 08, 2015 0:55
It looks like everything is setup correctly in your code.
You could try to temporary set similar settings on Page type instead for a Block type and see if the pages are restirected.
You could also check access rights for block in admin mode:  Admin->Content Type -> PageTitleBlock -> Settings -> Access Level
Or maybe there is a problem with roles assigned to user that you are using to test - he has BlockCreators role.
#139864
Oct 08, 2015 9:29
I've been checking to see if the access rights were applied correctly at the screen you mentioned; just shows "Everyone" for the new block. I also just did a quick test creating a new page type, and had the same results.
I made sure the role exists in the system (in case that made a difference), but got the same results.
#139886
Oct 08, 2015 16:33
Did you try clicking the "revert to default" in admin mode?
#139902
Oct 09, 2015 9:51
That was the last thing I tried last night, and it did indeed reset the Access level to the one specified in code. Is that the expected behavior?
#139917
Oct 09, 2015 15:41
I would expect it to use whatever you had specified in your code, so no. Perhaps if you changed the model at some point, it got "stuck" somehow?
#139919
Oct 09, 2015 15:46
