util/login.aspx throws 404
Hi everyone,
I've created a new EPiServer site using empty MVC project template.
I'm using version 7.15.0
On my local machine everything work fine. I can access the start page, log in to edit / admin mode, etc.
On the test server, I can only access the public web www.mydomain.com/... but when I try to access www.mydomain.com/util/login.aspx I get 404.
I tried to copy everything from my local machine (.cs files, app_data, modules, etc.) to the test server but it didn't solve the problem.
Any help would be greatly appreciated!
#115130
Jan 09, 2015 15:18
Problem solved.
The value for 'appData basePath' in web.config was wrong. I corrected this and pushed changes to the test server but Application Pool wasn't recycled.
After manual recycling everything works fine :)
You can also get 404 if you turn on 'Precompile during publishing' option in MSDeploy.
#115134
Edited, Jan 09, 2015 15:57
