I do not think so.
If I look at the tinymce page on configuration I can't see any way:
http://www.tinymce.com/wiki.php/Configuration
What you might be able to do is to hide it with some custom css, those rows has a id on them so this css should be able to hide them
#width_row {
display: none;
#styleSelectRow {
display: none;
The only.... but big problem is that the html code loaded in it is in a iframe so putting this css in the editor.css (or simular) does not help.
I can't figure out a way to pass these rules into the iframe now, saidly.. But, if you find a way, it should work
We have setup custom tinymce settings for differing pagetypes, all good with that.
One particularly group of settings is aimed towards table editing, what I wanted to know is, the menu you expose when you use the TinyMCEButtons.TableButtons.Table, is there a way to remove the highlighted options from this sub menu (probably not im guessing):
