Hello Frank
The meda folder will always synchronise the media folder when viewing an image. This means you can:
I hope the image below makes my thoughts clear:
Thank you very much for your fast response - and I apologize for my temper outburst. Regrettably I also forgot to start to say that I in general am satisfied with the userfriendly experience in episerver!
I am using a Mac Mini when working with Episerver. But unfortunately when I select a picture in a choosen media folder, it does not change the web address in the browser.
The web address in the browser only changes when I select a page in the page navigator. Maybe your suggestion only works in MS Windows OS?
Hello Frank
Something that's not clear from my image above is that you need to double click the picture in the media folder (not single click). This will show the picture in the main content area and also change the URL in the browser so you can bookmark it (this blocks too).
I use a Mac at home (Safari and Chrome) and confirm this behaviour still works. I tested this on the very latest release of EPiServer so if you cannot get this to work I'd suggest talking to your developers to ensure you are running on the latest release of EPiServer. If it still doesn't work then they can raise a bug with EPiServer developer support as this is expected behaviour.
Best regards
David
Thank you for the clarification.
If I have understood correctly, I first apply the picture URL bookmark (and select the media button) to open my default picture folder. Then I click the equivalent page URL bookmark to open the default page location in the page navigation structure. So now I have default page as well as default picture folder in focus! :)
And if I want to insert a picture when designing a new page I just have to drag the picture over and drop it. I can also paste the picture folder path /EPiServer/CMS/Content/globalassets/... in the URL field in the "Insert picture" property.
In short this procedure makes it quite easy to add pictures when designing pages!
I am working (on my spare time) as a web administrator.
Each time when I want to upload - or insert a picture (when designing a page), from a media folder, I have to expand (navigate down) the whole folder structure to select a the picture.
Since this repeated folder navigation is just unacceptable ineffective (and a stupid waiste of time), I should rather be able to define a default media folder - in my user preferences - that is applied each time I want to access this folder.
Any suggestion on how this is achieved?
Regards
Frank
