EPiServer 7.15.0.0 and error messages
I'm using SquishIt in one of the EPiServer projects.
Everything works fine on my local machine, even when I use .ForceRelase(), but on the test server I'm getting a login page.
If I use .ForceDebug() on the test server, then everything works fine but js / css files are not bundled.
I guess that EPiServer / ASP.NET throws an exception for some reason, but I don't know which one.
Error log is empty, and I see nothing strange in network tab (google chrome dev tools).
Can I configure EPiServer to show error messages instead of the login page, or do I have to manually log error messages by attaching to some events in Global.asax.cs?
#115817
Jan 19, 2015 15:48
I played a bit with Error Handling under Admin / Config / System Settings, and noticed that application cannot modify web.config file.
After granting Full Control to AppPool Identity user, everything works fine.
#115925
Jan 21, 2015 12:13
