You can create custom getters for your model properties that implements default values. There is an example of this in the Alloy templates where a default image is returned if no image has been selected.
Thank you. So simple. Dont know why I didn't figure this out myself hehe.
For others reading. This is the code from alloy:
[DefaultDragAndDropTarget]
[UIHint(UIHint.Image)]
public virtual Url Url
get
var url = this.GetPropertyValue(b => b.Url);
return url == null || url.IsEmpty()
? new Url("/Static/gfx/logotype.png")
: url;
set
this.SetPropertyValue(b => b.Url, value);
If I would use the SetDefaultValues method of the PageData object to give my properties a default value it would only affect pages that are created after this change.
I understand that if episerver would change properties on previously created pages that would be a big risk and I don't mean to change this.
What I would like to do however is to return a fallback value from the model if the property is not set.
Lets say I have this new property
This property would be the text limit of the excerpt in a search result. Since the search page is already created this would just result in the property returning 0 even if i would set it to 200 in SetDefaultValue method.
Is there any way to return a value that is not based on the property value if the property is not set? I still want to access the property CurrentPage.ExcerptLength to retrieve this. What I mean to say is that I don't want to handle the fallback value in controller or any extra read-only property on the model.
Best regards
Andreas
