AmazonEventProvider Issues
swc
swc
We're running EpiServer 7.8.2, and attempting to use EpiServer.Amazon package 7.8.2 as well.
We have two nodes that we want to notify each other of content being published, ect, so I tried to set up the AmazonEventProvider by adding the following to our web config in the episerver.framework element:
But when I try to run the site, I receive the following error:
Method not found: 'Amazon.SimpleNotificationService.AmazonSimpleNotificationService Amazon.AWSClientFactory.CreateAmazonSNSClient(Amazon.Runtime.AWSCredentials, Amazon.RegionEndpoint)'.
Does the Amazon Event Provider not work in this version of EpiServer, or is there some additional configuration needed that is missing?
Thanks.
#91209
Sep 29, 2014 23:37
swc
And to be clear, we are already using Amazon S3 as the blob store provider without issue, so the EpiServer.Amazon nuget package is referenced correctly.
#91210
Sep 29, 2014 23:42
Make sure you run NuGet package AWSSDK 1.5.x and not 2.x since there is a breaking change in that version.
Also, I would suggest upgrading to CMS.Core 7.14 if you are planning to use the Amazon Event Provider:
http://world.episerver.com/Documentation/Release-Notes/ReleaseNote/?releaseNoteId=117212
#91223
Sep 30, 2014 8:19
swc
Hello Per,
Thanks, but we are using AWSSDK 1.5.55, along with EPiServer 7.8.2 when receiving the above error, so that should not be the issue.
That said, perhaps we will wait until we're able to upgrade to 7.14 if there appear to be additional issues.  I'm stll curious why this wouldn't at least marginally work, though.
#91298
Oct 01, 2014 22:15
