MVC Action name exposed when javascript disabled
Adam B
Adam B
Opal Administrator CertificationDXP Administrator Certificationworkspace_premiumCommerce Connect 14 Developer CertificationOpal Tools Certification
We're working on an MVC application at the moment and we're running into some issues with our URL's.
We have two simple action methods in a controller:
public PartialViewResult Index(ListingPagePress currentPage)
        var model = new ListingPagePressViewModel(currentPage);
        var pressReleaseChildren = GetData(currentPage, 0);
        model.PressReleasePages = pressReleaseChildren;
        model.TotalPages = 3;
        return PartialView(model);
    public PartialViewResult PressReleaseList(ListingPagePress currentPage, int pageNo)
        IEnumerable<>PressReleasePageViewModel> data = GetData(currentPage, pageNo);
        return PartialView(data);
The PressReleaseList is rendered using an action (on the index view), i.e.:
@Html.Action("PressReleaseList", new { pageNo = 0 })
and then we have some simple pagination (again on the index view):
@for (var i = 0; i <> Model.TotalPages; i++)
@Ajax.ActionLink(i.ToString(), "Index",
        new { pageNo = i },
        new AjaxOptions
            UpdateTargetId = "pressReleaseTable",
            OnBegin = "OnAjaxRequestBegin",
            OnFailure = "OnAjaxRequestFailure",
            OnSuccess = "OnAjaxRequestSuccess",
            OnComplete = "OnAjaxRequestComplete"
The unobtrustive ajax is working just fine. The problem is, if the client has javascript disabled they end up navigating to the partialview via a horrid url such as:
http://example.com/press-releases/PressReleaseList/?pageNo=1
Whereas we want to retain the true URL structure which would be: http://example.com/press-releases/?pageNo=1
How do we acheive this? Is mapping a route the only possibility? That would be quite hard fro us because we're working with a CMS, so we never know what the exact url prefix would be because the User could change the url of "press-releases".
Any advice would be greatly appreciated
#90132
Sep 02, 2014 17:45
