Via code?
In the EPiServer GUI you could move the page /w drag-n-drop to another parent or use cut-n-paste.
Found a solution. Call DataFactory.Instance.Move when page is beeing published.
Hi Anders,
Your server code is a best way, I just want to introduce an alternative way using client side ;)
var contentDataStore = registry.get("epi.cms.contentdata"),
contentStructureStore = registry.get("epi.cms.content.light");
// Listen change content status actions
aspect.around(contentDataStore, "executeMethod", function (originalMethod) {
return function (method, id, data, options) {
return when(originalMethod.apply(contentDataStore, arguments), function (result) {
if (result && result.success && epi.areEqual(method, "ChangeStatus")) {
var saveAction = ContentActionSupport.saveAction,
action = ContentActionSupport.action,
currentAction = data && data.action;
switch (currentAction) {
case action.Reject:
// TODO: Do whatever you want
break;
case action.Publish:
// Move the published page to new destination
when(contentStructureStore.move(id, {targetId: publishedPageContainer /*Replace with your real content reference*/ }), function(moveContentResult) {
topic.publish("/epi/cms/contentdata/childrenchanged", publishedPageContainer);
break;
case action.CheckIn:
break;
case saveAction.CheckIn | saveAction.DelayedPublish | saveAction.ForceCurrentVersion:
break;
default:
break;
return result;
Happy coding!
Ha Bui
Is it possible in any way to change the ParentLink of a page while the page is published?
The ParentLink property (args.Page.ParentLink) seems to be read only.
