"View as" not working in custom top menu
I have a top menu that loads the top pages using the following code:
//get top level pages visible and in menu
IEnumerable allChilds = repository.GetChildren(ContentReference.StartPage);
IEnumerable filteredChilds = FilterForVisitor.Filter(new PageDataCollection(allChilds)).Where(p => p.IsVisibleOnSite() && p.VisibleInMenu);
My problem is that when the editor is using the "view as" and enables a specific visitor group, everything changes as it should except the menu. It seems like the p.IsVisibleOnSite() ignores the  chosen visitor group"
How can I fix this, anyone got any ideas?
#88971
Aug 05, 2014 10:28
IsVisibleOnSite() has nothing to do with access rights, ref:
http://world.episerver.com/Documentation/Class-library/?documentId=cms/7.5/8726F47F
FilterForVisitor.Filter() runs FilterPublished(), FilterAccess() and FilterTemplate().
I thought that FilterAccess would remove any pages not relevant for chosen visitor group.
Could you try also running FilterContentForVistor?
#88976
Aug 05, 2014 12:08
Thankyou for your answer Mari.
Tried FilterContentForVistor and same result. Note that this works perfektly in non-admin mode, using the same code. So I am thinking its editor-mode related.
#88981
Aug 05, 2014 13:34
Ah, then FilterForVisitor does what it's supposed to.
I did a quick test in one of my projects and it works both from view mode and using "View as" functionality (using version 7.8). I gave access rights (read access) to the visitor group and removed read access for "Everyone" for the test-page.
#88982
Aug 05, 2014 14:02
Mari, could you elaborate? Should I do extra tests in admin mode. Basically I just want to emulate what the users see. I'm on 7.5
#88985
Aug 05, 2014 14:18
To test I did the following in edit mode:
  • Edit one of the pages in that is part of the main menu
  • Using the "Visible to" property I removed read access for "Everyone" and added read access for "VisitorGroup A"
  • I then navigated to start page, used "View settings" (eye icon) to select view for "VisitorGroup A".
  • I also opened the site in another browser where I was not logged (not part of visitor group) in to verify that the page was not visible
#88990
Aug 05, 2014 15:06
