Using Azure Service Bus as evenhandler for local site
I have just tried to use Azure Service Bus as event handler instead of regular udp or tcp and can't get it to work. Is it so that it only works in Azure and can't be used on a "local" site?
#88931
Aug 04, 2014 15:27
Wow, just noticed the most strange bug/feature when trying this.
If I have defined to use Azure service bug as the default eventhandler this is what happens.
I open a page for editing and for example change the ingress (standard string) it all looks good, then I reload the page (in on page edit mode) and then the old text is back but if I click in the ingress I see the updated text so it has been saved but when loaded from cache it is using the old version.
I tried to remove the settings to use Azure Servicebus and restart the site and recycle the application pool and then it is working as it should.....
Anyone seen this behavor anytime?
#88937
Aug 04, 2014 16:13
