After a few extra attempts with the sql scripts executing them manually, the last 7.11 finally seemed to work, and now it is working ok.... very "stable" scripts don't you think?
I have migrated to EpiServer CMS Framework 7.13 and i get the same
After running the update.bat c:\inteput\mySite... script, there is an error in the log saying:
2014-08-15 13:58:10,143 [159] ERROR EPiServer.Global: 1.2.5 Unhandled exception in ASP.NET
System.Data.SqlClient.SqlException (0x80131904): Could not find stored procedure 'netContentDataLoad'.
Upgrading files are
7.8
7.10
7.11
Any ideas?
The SP 'netContentDataLoad', is it removed by the scripts? or should it be added?
Is there an easy way to see if the scripts have been executed successfully?
