Render block in Xhtml-field
I have a pretty plain block, with image, link and text. I have tried to drag n drop it to a xhtml field, but all it renders are the block name.
Puff
The block works fine in a content area.
#89861
Aug 27, 2014 15:10
What does the source look like in TinyMCE while in edit mode? It should look something like this where the block is inserted:
The important part here is the data-classid and data-contentlink attribute. The block cannot be found if those are missing.
The rendering of the block does not work either if you have the focus inside TinyMCE.
#89867
Aug 27, 2014 20:18
And by the way, how are you rendering the xhtml property in the template/view? And which base class do you inherit from in your block renderer?
#89868
Edited, Aug 27, 2014 20:19
The source inside the timy mce editor looks like this:
I render the xhtml property like this:
And I inherit from the BlockControlBase in my block renderer. I also got the tag "MainBodyStandard" on mu block.
#89888
Aug 28, 2014 9:22
This is what causing the problem:
EPiServer.Core.PropertyDataCollection.GetHandler = new GetPropertyDelegate(EPiServer.EmailPropertyGetHandler.EmailPropertyHandler);
The EmailPropertyHandler converts mailto inks to links to contact forms. Unfortunatly it also strips the data-contentlink and the data-classid from the:
Is it possible that the GetPropertyDelegate cant hadle the data-tags?
#90068
Sep 01, 2014 17:21
What is EmailPropertyHandler? Is that a third party plugin?
#90069
Sep 01, 2014 18:45
No, its a custom written method that converts email andresses in mainbody into adresses to contact form.
 public static PropertyData EmailPropertyHandler(string name, PropertyDataCollection properties)
            if (name.Equals("MainBody")
PropertyData property = properties.Get(name);
//////[Code]/////
Already on the last line there the data-classid and the data-contentlink attributes for the block is gone.
I think it is the same when I use the DefaultPropertyHandler (from EPiServer.Core.PropertyGetHandler).
#90090
Sep 02, 2014 9:31
Hi, we have the same problem when trying to modify the mainbody on the publishing event.
public virtual void OnPublishing(PageEventArgs ea)
    var mainBody = ea.Page.Property["MainBody"].Value;
    // Here is data-classid and data-contentlink gone
We are using Slimresponse and we modify the image tags in the MainBody to achieve responsive images.
This seems to break the block rendering in Xhtml.
#90093
Sep 02, 2014 9:42
Has anyone found a solution to this problem?
#90672
Sep 16, 2014 9:13
If you cast the property to a XhtmlString and then use the method .ToInternalString() it seems like you get what you are looking for.
Edit: You may need to cast the property to an XhtmlStringProperty and then the value to a XhtmlString.
#90681
Edited, Sep 16, 2014 10:43
Thank you Erik!
.ToInternalString() worked!!! :-)
#90685
Sep 16, 2014 10:57
