Datafactory deleted page event
In EPI 7.5, I cannot get the page deleted/deleting event to fire when removing pages through the GUI.  It doesn't fire on moving an item to the tash, nor when I empty the trash.  I can successfully hook in to other events (like creating/created), just nothing on delete.
Is this a bug, known behavior, or just a coding failure on my part?  I want to do some cleanup post delete.  I've seen some older posts dealing with EPi 6 and emptying the trash, but nothing on 7.5
EDIT: after more testing, it appears like the delete event is called, but I'm given the content ID of the wastebasket itself, rather than for each page in the wastebasket.
Shawn
#89220
Aug 11, 2014 18:03
The event args to the Deleted event has a property DeletedDescendents that will be set with all descendents that will be deleted. When emptying wastebasket a call is made to DeleteChildren with wastebasket as argument which is the cause that it is the wastebasket id you see.
#89241
Aug 12, 2014 7:28
