Using the BlobFactory to store images
Hi.
I'm trying to store an image with the BlobFactory, but I'm obviously doing something wrong. The image gets stored, but when I try to download it. The image viewer on my machine says it either too large or corrupted. It's probably corrupted, because before I upload the picture I can view it in the image viewer.
This is my code:
var file = _contentRepository.Service.GetDefault(SiteDefinition.Current.GlobalAssetsRoot);
			file.Name = httpPostedFileBase.FileName;
			var blob = _blobFactory.Service.CreateBlob(file.BinaryDataContainer, Path.GetExtension(httpPostedFileBase.FileName));
			using (var s = blob.OpenWrite())
			using (var sw = new StreamWriter(s))
			using (var sr = new BinaryReader(httpPostedFileBase.InputStream))
				sw.Write(sr.ReadBytes(Convert.ToInt32(httpPostedFileBase.InputStream.Length)));
			file.BinaryData = blob;
			return _contentRepository.Service.Save(file, SaveAction.Publish, AccessLevel.NoAccess);
I've been following this post. In this example he only stores text to a .txt file, which is not what I need.
I've tried to use a StreamReader and .ReadToEnd and that returns a string. I've also tried the BinaryReader (as shown in the code above), but no luck there either.
Does anyone know how to store images properly?
// Anders
#88374
Jul 10, 2014 10:37
Here's some sample code that I've used in the past:
HttpPostedFileBase uploadedFile = Request.Files[i];
if (uploadedFile == null || uploadedFile.ContentLength == 0)
	continue;
var genericMedia = this._contentRepository.GetDefault(rootFolderContentReference);
genericMedia.Name = uploadedFile.FileName;
var blob = this._blobFactory.CreateBlob(genericMedia.BinaryDataContainer, Path.GetExtension(genericMedia.Name));
blob.Write(uploadedFile.InputStream);
genericMedia.BinaryData = blob;
this._contentRepository.Save(genericMedia, SaveAction.Publish, AccessLevel.NoAccess);
Hope it helps.
Frederik
#88380
Jul 10, 2014 11:39
This worked. In the example in the post I followed, the Blob needs to be opened for writing first and then use a StreamWriter to write to the blob, but you're just writing directly and it works. Why is that?
Thank you so much for your help, Frederik.
// Anders
#88384
Jul 10, 2014 12:32
