Hi, not sure exactly what you are after, it depends if your are working with MVC or with Webforms. But you can have a look in the two diffrent template packages that episerver has developed, one for MVC and one with Webforms. The websites can be installed with both Visual studio plugin or with Deployment Center. You will find example on hot to create these menus.
yes I have installed the same, but i want a dynamic menu for example we have main categories pages and as we add some sub category pages under main category these pages should be show under respective category .
Not sure what you are after but these menus that are in the template package is dynamic an not static. The function behind them is slightly diffrent then what you are asking for could be created in these menus as well you just need to alter the functionality for your needs. I might need to create filter or set the startingpoint for the menus a bit diffrent then the example.
Have you had a look at the getting starting section: http://world.episerver.com/Documentation/CMS/Get-started-with-CMS/Introduction/
Hi ,
I am new developer for EPiserver 7.5.
i am able to create single horizontal menu but ,
how to develop multilevel nevigation menu, please help some or provide any step by step article .
Regards
Umesh
