Somewhere in your prodject you seem to have a dependancy to EPiServer, Version=5.2.375.133. I would start by checking your assembly redirectes in web.config and any plugins added to the site. If you can't see anything suspicious then fire up fuslogvw and see what assembly is asking for the 5.2 version of episerver.
Unable to load one or more of the requested types. The following information may be a subset of the Type/LoaderException information present - inspect with debugger for complete view.
Check assemblies [EPiServer.Legacy4, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7] and/or types [EPiServer.Enterprise.Transfer.EPi4.AutoCorrectionPageDefinitionEventArgs,
EPiServer.Enterprise.Transfer.EPi4.AutoCorrectionPropertyEventArgs,
EPiServer.Enterprise.Transfer.EPi4.DataImporter,
EPiServer.Enterprise.Transfer.EPi4.DynamicPropertyValueTransfer,
EPiServer.Enterprise.Transfer.EPi4.PageTransfer,
EPiServer.Enterprise.Transfer.EPi4.PageTypeTransfer,
EPiServer.Enterprise.Transfer.EPi4.PropertyCategoryTransform,
EPiServer.Enterprise.Transfer.EPi4.PropertyLongStringTransform,
EPiServer.Enterprise.Transfer.EPi4.PropertyPageReferenceTransform,
EPiServer.Enterprise.Transfer.EPi4.PropertyStringTransformer,
EPiServer.Enterprise.Transfer.EPi4.PropertyUriTransform,
EPiServer.Enterprise.Transfer.EPi4.PropertyXFormTransformer,
EPiServer.Enterprise.Transfer.EPi4.SetUp,
EPiServer.PageTreeLoader,
EPiServer.PageTreeReader,
EPiServer.PageTreeXml,
EPiServer.SpecializedProperties.PropertyStringReadOnly,
EPiServer.SystemControls.ValidationSummary,
EPiServer.WebControls.CategoryTemplateContainer,
EPiServer.WebControls.CategoryTree]. Information from LoaderExceptions property [Method 'TryAddBlob' in type 'EPiServer.Enterprise.Transfer.EPi4.NativeFileTransferEPi4' from assembly 'EPiServer.Legacy4, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' does not have an implementation.,
Method 'OpenWrite' in type 'EPiServer.Enterprise.Transfer.EPi4.NativeFileTransferObject' from assembly 'EPiServer.Legacy4, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' does not have an implementation.].Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. The following information may be a subset of the Type/LoaderException information present - inspect with debugger for complete view.
Source Error:
[No relevant source lines] |
Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\5d63dc1d\9a7e7873\App_global.asax.0.cs Line: 0
Stack Trace:
[ReflectionTypeLoadException: Unable to load one or more of the requested types. The following information may be a subset of the Type/LoaderException information present - inspect with debugger for complete view. Check assemblies [EPiServer.Legacy4, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7] and/or types [EPiServer.Enterprise.Transfer.EPi4.AutoCorrectionPageDefinitionEventArgs, EPiServer.Enterprise.Transfer.EPi4.AutoCorrectionPropertyEventArgs, EPiServer.Enterprise.Transfer.EPi4.DataImporter, EPiServer.Enterprise.Transfer.EPi4.DynamicPropertyValueTransfer, EPiServer.Enterprise.Transfer.EPi4.PageTransfer, EPiServer.Enterprise.Transfer.EPi4.PageTypeTransfer, EPiServer.Enterprise.Transfer.EPi4.PropertyCategoryTransform, EPiServer.Enterprise.Transfer.EPi4.PropertyLongStringTransform, EPiServer.Enterprise.Transfer.EPi4.PropertyPageReferenceTransform, EPiServer.Enterprise.Transfer.EPi4.PropertyStringTransformer, EPiServer.Enterprise.Transfer.EPi4.PropertyUriTransform, EPiServer.Enterprise.Transfer.EPi4.PropertyXFormTransformer, EPiServer.Enterprise.Transfer.EPi4.SetUp, EPiServer.PageTreeLoader, EPiServer.PageTreeReader, EPiServer.PageTreeXml, EPiServer.SpecializedProperties.PropertyStringReadOnly, EPiServer.SystemControls.ValidationSummary, EPiServer.WebControls.CategoryTemplateContainer, EPiServer.WebControls.CategoryTree]. Information from LoaderExceptions property [Method 'TryAddBlob' in type 'EPiServer.Enterprise.Transfer.EPi4.NativeFileTransferEPi4' from assembly 'EPiServer.Legacy4, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' does not have an implementation., Method 'OpenWrite' in type 'EPiServer.Enterprise.Transfer.EPi4.NativeFileTransferObject' from assembly 'EPiServer.Legacy4, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' does not have an implementation.].] EPiServer.Framework.Initialization.InitializationModule.Initialize(HostType hostType) +792 EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +104 EPiServer.Global..ctor() +110 EPiServer.Templates.Global..ctor() +40 ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\5d63dc1d\9a7e7873\App_global.asax.0.cs:0 [TargetInvocationException: Exception has been thrown by the target of an invocation.] System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0 System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +159 System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +256 System.Activator.CreateInstance(Type type, Boolean nonPublic) +127 System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +14259449 System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +200 System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +28 System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +83 System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +312 System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +475 [HttpException (0x80004005): Exception has been thrown by the target of an invocation.] System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +12968244 System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +159 System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +12807949 |
Try to figure out as Petter mentioned and also check your references in your project for old versions. External projects/plugins might reference an old version of episerver since you have done an upgrade.
There might be some old assemblies in your bin folder that you need to remove as well.
Did you solve the problem Gayatri.. For that you need to remove the EPIServer.Legacy reference and also from bin folder . It should work after that.
Server Error in '/' Application. Could not load file or assembly 'EPiServer, Version=5.2.375.133, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileLoadException: Could not load file or assembly 'EPiServer, Version=5.2.375.133, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Source Error:
Assembly Load Trace: The following information can be helpful to determine why the assembly 'EPiServer, Version=5.2.375.133, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' could not be loaded.
Stack Trace:
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18446
