Foreign key violation when deploying site
I'm getting foreign key violations when deploying out new version of a site. It looks like the autogeneration of properties has failed. Is it possible to delete a property type of a page/block then allow the site to regenerate it.
Currently I am fixing by
  • deleting the property in code then deploying out
  • deleting the property in the admin console
  • restoring the property
  • redeploying the site
Clearly this isn't a long term solution. I need to be able to fix it in situ - without the need for 2 additional deployments of the site.
My error is
The INSERT statement conflicted with the FOREIGN KEY constraint "FK_tblWorkContentProperty_tblPropertyDefinition". The conflict occurred in database "NITB_MIGRATION", table "dbo.tblPropertyDefinition", column 'pkID'.
Many thanks for any all help
#87400
Jun 12, 2014 13:16
You have a stack trace?
#87480
Jun 13, 2014 15:54
Mmmm it's stopped erroring now but it isn't saving. On publsih the field reverts to an empty string. I'll see if it starts to error again
#87485
Jun 13, 2014 17:09
I've redeployed and got another FK error so this is cropping up a lot. The error is
So same/similar
I'm going to raise a bug report about this as it's a geninue app issue
#87769
Jun 23, 2014 13:30
You can delte Existing PageTypes/Bock Types If these have not been used from Admin mode.
Most probably some page/Block/media/meta type with that guid already exist.
/K
#87777
Jun 23, 2014 14:31
Thanks for the input but unfortunately this isn't it. The Guids are OK and unique. Thanks
#87783
Jun 23, 2014 15:03
