Dynamically create Categories
Is there a way to dynamically create categories from my c# code which I can use in the categories field in EPiServer?
I have found a way to do this:
var root = Category.GetRoot();
root.Categories.Add(new Category("name", "description"));
However, this should be done once on EPiServer initialization. Should I create a plugin or use a descriptor for it?
Hope somebody can help!
#87842
Jun 24, 2014 13:16
Hello Hans
It sounds like you should use an EPiServer Initialisation module for this:
http://world.episerver.com/Documentation/Items/Developers-Guide/EPiServer-Framework/7/Initialization/Creating-an-Initialization-Module/
It might also be worth checking for the existence of the category before inserting it to avoid any issues.
David
#87847
Edited, Jun 24, 2014 14:04
I'm using following fragment to create new categories from code (keep in mind that code will execute *every* time app pool will start - so you should take care of avoiding multiple creation of the same category):
namespace MyProject.Web.Initialization
    [InitializableModule]
    [ModuleDependency(typeof(InitializationModule))]
    public class CategorySetup : IInitializableModule
            CreateIfNotExists("Key", "Display Name", 1);
        private void CreateIfNotExists(string name, string description, int order)
            if (string.IsNullOrEmpty(name))
                throw new ArgumentNullException("name");
            if (string.IsNullOrEmpty(description))
                throw new ArgumentNullException("description");
            var categories = CategoryList.LoadCategories();
            if (categories.Contains(name))
                return;
            var category = new Category(name, description)
                                   Available = true,
                                   Parent = Category.GetRoot(),
                                   SortOrder = order
            category.Save();
#87852
Edited, Jun 24, 2014 14:24
