Change filepath of default blob provider
Can I change the filepath of the default blob provider. I would like it to look at a shared filepath but I want to keep all other files under appdata  i.e. Modules. I don't really want to write my own blob provider to achieve it - if it's possible with the default then great otherwise I think i will just live with all appdata on a shared location
Thanks for any all help
Tim B
#87395
Jun 12, 2014 12:08
Hey, Tim, which version exactly are you using?
In EPi 7.6 and on, Modules are under wwwroot/modules/_protected, while blobs are inside a shared folder. If I understand correctly, this is what you want to achieve?
Is upgrade an option for you?
#87399
Jun 12, 2014 12:55
<episerver.framework>
  <blob defaultProvider="fileShare">
    <providers>
      <add name="fileShare" path="d:\path\to\blobs" type="EPiServer.Framework.Blobs.FileBlobProvider, EPiServer.Framework" />
    </providers>
  </blob>
</episerver.framework>
#87402
Jun 12, 2014 14:23
Thank you Torjus that's worked
#87473
Jun 13, 2014 14:09
