My renderer inherits from ContentControlBase, which in turn inherits from UserControlBase which implements IRenderSettings. But the RenderSettings property is always empty! Even if I add one of the typed settings like Tag, it's still empty.
However, if I traverse the control tree up to the PropertyDataControl, I can find all the settings.
Is this is a bug? Shouldn't the renderering settings be set in ContentControlBase?
I blogged about this a while back before I knew about IRenderSettings, http://dodavinkeln.se/post/custom-rendering-settings. Then I tried to access RenderSettings in a shared block, and that worked! But it seems like it doesn't work with local blocks.
error This topic was created over six months ago and has been resolved. If you have a similar question, please create a new topic and refer to this one.
I have a simple local block with address data. I'm rendering the block with the property control:
