Error in Upgrade from 7 to 7.5
After upgrade the site from 7 to 7.5 i have the following issue
http://imgur.com/ERtSonu
and in web.config i have the following
<episerver.packaging protectedVirtualPath="~/secure/" protectedPath="modules/_protected" publicVirtualPath="~/modules/" publicPath="modules"/>
Any ideas how to fix it?
#87397
Jun 12, 2014 12:27
Do you have the paths? You should have a modules folder.
Have a look at a clean install of cms 7.5 could be a sugestion and check the path on that installation. Believe you have something with probingpath that could be worth looking into.
#87643
Jun 18, 2014 15:16
