XForms CSS class not applied to textbox or textarea
I think I've just discovered a bug in 7.5, I'm not sure about earlier versions though.
Using XForms when configuring your form through the editor, if I enter a value into the CSS Class field on a textbox or textarea, that value isn't applied when the form is rendered. The whole class attribute is missing.
It works as expected on drop-down lists, radio buttons, checkboxes, buttons and headings.
Please can someone look into this issue?
Cheers
Jonathan.
#86720
May 29, 2014 1:31
Hi, Jonathan,
If you don't get this fixed, you can fully customize the rendering of XForm elements. Check out Ove's article here.
For me, it works well and it's easier for GUI guys to style it as well, since it's not rendered with tables.
#86733
May 29, 2014 10:00
Hi Marija
Yeah I'd already got rid of those pesky tables but didn't customise it to the level Ove has.
I still think it's a bug though as out of the box EPiServer doesn't function as it should for textboxes and textarea.
Thanks for the link
Jonathan.
#86762
May 30, 2014 1:37
Is this the bug Jonathan?
http://world.episerver.com/Support/Bug-list-beta/bug/103642/
#86763
May 30, 2014 2:10
Hi Toni
That's it! Sorry, I did search the bug list. Obviously not very well though.
The bug report suggests it's for every field type where as I'm only experiencing the issue with a couple of them.
Cheers
Jonathan.
#86764
May 30, 2014 2:20
Jonathan: Try then to upgrade to EPiServer UI 7.8. (patch 14) and see if it has been resolved.
#86791
May 30, 2014 17:05
Thanks Toni. Unfortunately we're not in a position to upgrade at present, too many parties involved. It's good to know that it is resolved in the latest version though.
#86800
Jun 02, 2014 3:37
