It seems to be a missing translation key for those languages. What do you have setup as fallback language in the EPiServerFramework.config?
If you set fallback culture to en I imagine that things should start working. This should be considered a bug however.
I have Finnish as the fallback language. I changed that to English as you suggested and it fixed the problem. Thank you!
I'll do a bug report of this anyways so hopefully it'll be fixed for the next release.
Is there a bug reference id for this? I can't seem to find it in the bug list.
Cheers! //Mathias
This have been fixed since a few months ago:
http://world.episerver.com/Support/Bug-list-beta/bug/114390/
Did a local upgrade and that sorted it. I'll see about doing it in the other envs as well. Thanks Linus!
After installing the latest patch 14 Edit mode is broken when using it in Finnish or Swedish. English seems to work fine though. It might be that other languages are broken too but I only tried these. Admin-mode seems to work fine. When accessing the Edit mode only part of the left side page tree panel is rendered, nothing else. In the console I get the following error:
Any idea what might be causing this?
