Export property wont include settings
I want to use an standard dropdown and let the admins decide the values.
But I want to prepoulate the list with data that today is the most recent values. We have a lot of enironments and the list of values is long.
So I tried to enter the values in the global/custom settings dialog in admin mode under edit propert.
The problem is that the values don get exported tho the other environments when i export the page/pagetype.
Any Ideas?
#86084
May 13, 2014 16:50
Does anybody know how to access the settings made in admin mode for the property by code?
I would like to read them if defined in my factory
  [UIHint("PublicationType")]
        [BackingType(typeof (PropertyDropDownList))]
        [Display(Name = "Publikationstyp", Order = 1, AutoGenerateField = true, Description = "Välj publikationstyp")]
        public virtual string PublicationType { get; set; }
        [UIHint(UIHint.MediaFile)]
        [Display(Name = "Pdf")]
        public virtual ContentReference PdfFile { get; set; }
        [EditorDescriptorRegistration(TargetType = typeof (string), UIHint = "PublicationType")]
        publicclassPublicationTypeEditorDescriptor : EditorDescriptor
                SelectionFactoryType = typeof (PublicationTypeFactory);
                ClientEditingClass ="epi-cms/contentediting/editors/SelectionEditor";
        privateclassPublicationTypeFactory : ISelectionFactory
            public IEnumerable<ISelectItem> GetSelections(ExtendedMetadata metadata)
//GET CODE FROM ADMIN SETTINS
//ELSE SHOW DEFAULT
                var types = new List<SelectItem>();
                types.Add(new SelectItem() {Value = "Rapporter", Text = "Rapporter"});
                types.Add(new SelectItem() {Value = "Skrivelser", Text = "Skrivelser"});
                types.Add(new SelectItem() {Value = "Informationsmaterial", Text = "Informationsmaterial"});
                return types;
Anyone???
#86118
May 14, 2014 10:59
