TinyMCE removes custom attributes
Hello,
I'm trying to add the HTML 5 sandbox attributes to an iFrame in the TinyMCE editor, except everytime I update, it removes the attributes. I've read how you can get round this in Episerver 6 but when this workaround http://www.frederikvig.com/2010/10/how-to-add-support-for-iframes-and-other-elements-to-tinymce-in-episerver-cms/ is applied it tends to break the editor in Episerver 7.5. Can anyone provide any help on how to resolve this issue.
Many Thanks
Paul
#86050
May 13, 2014 9:11
After much searching I've discovered the answer. I found this blog entry by Chris Sharp who explained why this doesn't work in Episerver 7 and how to get round it. http://cjsharp.com/blog/2013/04/15/how-to-add-valid-elements-like-iframes-to-tinymce-in-episerver-7/
Here's the code in case the link doesn't work in the future:-
Extended Valid Elements Code
[TinyMCEPluginNonVisual(PlugInName = "TinyMceExtendedValidElements", AlwaysEnabled = true, EditorInitConfigurationOptions = "{ extended_valid_elements: 'iframe[src|frameborder=0|alt|title|width|height|align|name]' }")]
public class TinyMceExtendedValidElements
Empty File Handler (for when the script is missing)
public class EmptyFileHandler : IHttpHandler
    public bool IsReusable
        get { return true; }
    public void ProcessRequest(HttpContext context)
Web.Config update
<configuration>
    ... some configuration ...
    <location path="util/editor/tinymce/plugins">
        <system.webServer>
            <handlers>
                <add name="TinyMceExtendedValidElements" path="/util/editor/tinymce/plugins/TinyMceExtendedValidElements/editor_plugin.js" verb="GET" type="MyEPiServerProject.Business.Handlers.EmptyFileHandler, MyEPiServerProject" />
            </handlers>
        </system.webServer>
    </location>
</configuration>
Episerver.Config update
<episerver>
<tinyMCE mergedConfigurationProperties="valid_elements, extended_valid_elements, invalid_elements, valid_child_elements" />
</episerver>
#86055
Edited, May 13, 2014 10:50
