The specified url https://localhost/ does not match any site. EPiServer 7.6.4
Under CMS->Admin->Config->Manage Websites-> choose specific website (http://mysite/cms/CMS/Admin/SiteInformationList.aspx then choosing appropriate website)
One can configure multiple Host names, for example:
  • localhost
  • mysite
  • test.company.org
  • and so on...
There is also section called URL, this is the only place where one can configure protocol, ie.: http://mysite or https://mysite
If http://mysite configured then following request works:
http://mysite/cms/cms/Stores/sitestructure/?siteUrl=http%3A%2F%2Fmysite%2F&allLanguages=true&dojo.preventCache=1401099189822
and this does not:
https://mysite/cms/cms/Stores/sitestructure/?siteUrl=https%3A%2F%2Fmysite%2F&allLanguages=true&dojo.preventCache=1401099189822
giving exception:
[ArgumentException: The specified url https://mysite/ does not match any site.]
   EPiServer.Cms.Shell.UI.Rest.SiteStructureStore.GetLanguageModelsForSite(String siteUrl, Boolean showAllLanguages) +1126
   EPiServer.Cms.Shell.UI.Rest.SiteStructureStore.Get(String siteUrl, Nullable`1 allLanguages) +221
   lambda_method(Closure , ControllerBase , Object[] ) +172
   System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +261
   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +39
   System.Web.Mvc.<>c__DisplayClass13.<InvokeActionMethodWithFilters>b__10() +124
   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +855266
   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +309
   System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +855200
   EPiServer.Shell.Services.Rest.RestControllerBase.ExecuteCore() +301
   System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +334
   EPiServer.Shell.Services.Rest.RestHttpHandler.ProcessRequest(HttpContextBase httpContext) +274
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +913
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +165
and once you configure 'CMS->Admin->Config->Manage Websites-> choose specific website' URL to https://mysite, then https version works properly and http one throws the same exception
and its even worse as one usualy have multiple hosts records in 'CMS->Admin->Config->Manage Websites-> choose specific website'
this does not work as well(while http://mysite configured in URL):
http://localhost/cms/cms/Stores/sitestructure/?siteUrl=http//localhost/&allLanguages=true&dojo.preventCache=1401099189823
Any pointers?
EPiServer 7.6.4 is used
PS. in all other aspects and other requests seems that protocol change and hostname change works properly.
#86698
May 28, 2014 15:19
#86699
Edited, May 28, 2014 15:20
