Would you mind to send me your data package? quma at episerver.com
Regards.
/Q
When im trying to import data from episerver 6 to episerver 7.5 I got an error saying:
Import has been canceled
The following errors have occurred:
[Importing content 25713_164563] Exception: Culture is not supported. Parameter name: name CZ is an invalid culture identifier.
I have Czech culture enabled on target and source.
How can i fix this. I tried rename export file to zip and change some CZ to CS but when i zip it again i got different filesize and episerver says its corrupt.
Any help is much appreciated.
/Johan
Bevan,
Would you mind sharing your solution here so we can use it for future reference?
Any updates on the "You must enter a value between 01/01/1753 and 12/31/9999 for "EPiServer.Core.PropertyDate"" error ?
Having the same issue when importing files (images).
I just experienced this too, and one possible error is:
Rename the exported file to Somename.zip, extract it and open all the different XML-files. In some of them, a language/culture is given at the root element. Does this match your page culture?
In my case it said en-US, even though all content that was being exported was nb-NO. I fixed all these, zipped the file back down and renamed to ".episerverdata". Upload and import => Success.
So it seems like a bug to me...
When attempting to import files from 7.0.586.16 into 7.7.1.0 all the content appears to import fine but none of my media files. The folders are created but the none of the images. The import data UI displays the message "You must enter a value between 01/01/1753 and 12/31/9999 for "EPiServer.Core.PropertyDate".
The log shows:
I see there was a post last year with the same issue which didn't appear to get a resolution: http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=79219
I need to be able to import this data otherwise I will not be able to migrate my site which makes upgrading pointless.
How can I get around this?
