var contentLoader = ServiceLocator.Current.GetInstance<IContentLoader>();
var repository = ServiceLocator.Current.GetInstance<IContentRepository>();
var archiveFolderRef = <%YourContentRefToArchiveFolder%>
var folder = repository.GetDefault<ContentAssetFolder>(archive);
foreach(var fileRef in fileRefs)
var mediaFile = repository.Get<MediaData>(fileRef)
folder.Attach(mediaFile);
repository.Save(folder, SaveAction.Publish);
I tried similiar code this afternoon, but I kept getting the following errors
"The specified content does not implement IResourcable and hence it cannot have a content asset folder"
Hi Petter
I reflected into MediaData source code, and I saw the MediaData didn't not implement the IResource interface, therefore folder.Attach method gets called, it throws that exception.
public virtual void Attach(IContent content)
Validator.ThrowIfNull("content", content);
IResourceable resourceable = content as IResourceable;
if (resourceable == null)
throw new ArgumentException("The specified content does not implement IResourcable and hence it cannot have a content asset folder");
if ((this.ContentGuid == Guid.Empty) || (content.ContentGuid == Guid.Empty))
throw new InvalidOperationException("Both content and ContentAssetFolder must have values assigned for ContentGuid before they can be attached");
if (string.IsNullOrEmpty(this.Name))
this.Name = content.Name;
resourceable.ContentAssetsID = this.ContentGuid;
this.ContentOwnerID = content.ContentGuid;
Hmm didn't have time to try my code while at work. And after playing some at home I still can't find a way to move the file. But I found a workaround.
The following code works in the alloy templates.
var contentAssetFolder = _contentRepository.Get<ContentFolder>(SiteDefinition.Current.SiteAssetsRoot);
var images = _contentRepository.GetChildren<ImageFile>(contentAssetFolder.ContentLink);
var folders = _contentRepository.GetChildren<IContent>(SiteDefinition.Current.SiteAssetsRoot);
foreach (var item in folders)
if (item.Name == "Events")
var folder = item;
ImageFile image = images.First() as ImageFile;
var newFile = _contentRepository.GetDefault<ImageFile>(item.ContentLink);
newFile.Name = image.Name;
newFile.BinaryData = image.BinaryData;
_contentRepository.Save(newFile , SaveAction.Publish);
_contentRepository.Delete(image.ContentLink, true);
Here I take the first file in the root folder and then find the Events folder and create a new item in it. Then set the new item to the same binarydata as the old one and save it. Then remove the old one.
Not the way I would want to do it but the only way I could figure out.
Tried with:
var folder = item;
ImageFile image = images.First().CreateWritableClone() as ImageFile;
image.ParentLink = folder.ContentLink;
_contentRepository.Save(image , SaveAction.Publish);
But that didn't work. So you could use the first snippet in wait for someone more in the know showing us how it's done =)
how about
_contentRepository.Move(mediaContentLink, destinationContentLink);
Hahaha way to easy ;)
Thanks Per. Most have been tired when checking the API.
Hehe, no problem.
Quick tip: If you need to find content matching a name, instead of using .GetChildren, looping through and checking for a matching name, you could instead do:
_contentRepository.GetBySegment(destinationContentLink, "events", null);
I have two media folders - upload and archive. There is a job running in the system processes the file that user uploads in the upload folder. Once it's complete, it needs to move the file to the archive folder.
I can retrieve all the files from the upload folder and process it programatically, but I don't have any clue how to link the processed file to archive folder, can some one provide a code sample?
thanks
