Error Creating Relate Site with Deployment Centre
I'm trying to create a Relate site using deployment center and it seemingly fails with an error that the login failed for the database user created for the site i.e. I specify usrSiteUser and the login fails for this.
The process then rolls back but does not complete as there is a file lock error when trying to delete the site (but that's another story).
I would like to know what causes the initial error and prevent it, at the moment I can't create a Relate site. Has anybody encountered this before?
For info I select Windows authentication in step 2 to access the database and I am logged onto the server as administrator. I have also logged in to SQL Server Management Studio using Windows authentication as the administrator and can create a database successfully.
Thanks in advance,
Mark
#86746
May 29, 2014 13:46
For information this was caused as the SQL Server only had Windows Authentication enabled. Enabling mixed mode resolved the issue.
#88189
Jul 04, 2014 11:46
