Consuming the IContentSecurityRepository ContentSecuritySaved event
The IContentSecurityRepository interface defines the ContentSecuritySaved event:
http://world.episerver.com/Documentation/Class-library/?documentId=cms/7.5/6a3b465b-0d98-387f-66b8-1b28132e1b7c
Where is this interface implemented and how can it be consumed?
#86778
May 30, 2014 14:02
You should be able to get hold of the interface implementation from IOC container (e.g. ServiceLocator.Current.GetInstance<IContentSecurityRepository>). It is singleton scoped. A typical usage would be to have an InitializableModule (with a DependecyModule attribute to EPiServer.Web.InitiailizationModule) where you would hook up your eventhandler. The event will be raised whenever access right is changed for a content item.
#86783
May 30, 2014 15:51
Thanks Johan.  Works perfectly, example below:
    [InitializableModule]
    public class SecurityEventInitializationModule : IInitializableModule
            var secRepos = EPiServer.ServiceLocation.ServiceLocator.Current.GetInstance<IContentSecurityRepository>();
            secRepos.ContentSecuritySaved += secRepos_ContentSecuritySaved;
        public void Preload(string[] parameters) { }
            secRepos.ContentSecuritySaved -= secRepos_ContentSecuritySaved;
        void secRepos_ContentSecuritySaved(object sender, ContentSecurityEventArg e)
            //todo: implement
#86822
Jun 02, 2014 12:22
