404 error when trying to set access rights on a Page
Hi there,
I'm facing a problem when trying to define access rights for any page in EPiServer. In the CMS administration, when I access Admin->Admin tab->Set access rights and click on any page on the tree, I get a 404 error, making me unable to define permissions for pages.
Also, going through the CMS Edit and edit the permissions from there doesn't work. When I press the button "Manage" from the property "Visible to", no matter what changes I do, the Save button is always unavailable.
What may be the issue here? What can I do to solve this problem?
Thank you and kind regards,
David
#86465
May 22, 2014 10:07
There is a bug reported that registration of ClassicLinkRoute route (that is a special route that handles "classic" links like '/templates/page.aspxx?id=77') will brake Set access rights.
#86545
May 23, 2014 11:55
Thank you for your answer, Johan. What workaround can I apply to solve this problem?
#86548
May 23, 2014 12:40
Are there any alternatives/recommendations for installations wishing to keep their classic templates/page.aspx/?id=1234 functionality working without having to use the ClassicLinkRoute route? Or, do we need to create an HttpModule or Handler for intercepting requests before they are handled by EPiServer?
#86675
Edited, May 28, 2014 11:10
What you probably could do is to create your own class that inherits ClassicLinkRoute and then override GetRouteData as:
  public override RouteData GetRouteData(System.Web.HttpContextBase httpContext)
           if (!httpContext.Request.Url.Path.StartsWith(EPiServer.Shell.Paths.ToResource("CMS", null)))
               return base.GetRouteData(httpContext);
           return null;
and then register your own route instead of ClassicLinkRoute
#86680
May 28, 2014 11:22
I just implemented this. And it works like intended.
I am now able to edit the "Set Access Rights" panel in Admin.
#86685
Edited, May 28, 2014 12:54
Still having trouble with the ClassicLinkRoute.
Even if I inherit the class, and in the GetRouteData method just returns null without any other code, some links in admin mode gets corrupted.
With the inherited class registered;
Dashboard url; http://site/?action=Index&controller=Dashboard&moduleArea=Shell
Addons url; http://site/?action=Index&controller=AddOns&moduleArea=EPiServer.Packaging.UI
Without adding the ClassicLinkRoute in registerRoutes;
Dashboard url; http://site/login
Addons url; http://site/login/AddOns
So, just by adding a class inherited by ClassicLinkRoute and returning null directly in GetRouteData will corrupt some admin urls. Other urls might be broken as well, I havnen't checked every corner of admin yet...
I hope EPiServer got some attention on this one, as it will be a major rewrite to workaround this at the moment. Is it possible for developers to get an insight into the bug registration site?
Any other ideas for us to try out?
#86775
May 30, 2014 13:39
Try override GetVirtualPath as well as:
public override VirtualPathData GetVirtualPath(RequestContext requestContext, RouteValueDictionary values)
            return null;
#86776
May 30, 2014 13:43
Thanks, didn't try that yet!
That did the trick, returning null kept the provider out of the loop.
Now, I am implementing the same rules in GetVirtualPath method, and first try looks promising.
Thanks for the help! When I have tested the code, I can post a reply with the implementation.
#86777
May 30, 2014 14:02
