Hey Joshua,
You can still use Url if you want to, you don't need to switch to ContentReference. However, if you are developing a new content type it is adviced to use ContentReference for images.
But in the future, If you ever choose to not allow this, Then we are stuck with the url and all items are obsolete now right?
The migration task should convert URLs that are softlinks. So if your link is in the softlinks table it should be taken care of.
Did you ever try this? I have the same problem and as far as I can tell I am stuck with Url. Trying to change the type of property will remove all links to images sadly. The migration did not make ContentReferences of the images that looked like this:
[Editable(true)]
[Display(
Name = "Image",
Description = "Choose an image to show",
Order = 10)]
[UIHint(UIHint.Image)]
public virtual Url Image { get; set; }
Good day,
I have a question in regards to typed models in which we used to in episerver 7 use the Url as the type returned and now we need to use the ContentReference. During the migration, all the conversions happen and what not and stored old urls in a table. SO if i were to switch my property to contentreference from Url, I cannot forsee this being handled appropiately for content being referenced as a Url. IS there a way around this or how have others done this. Example of setup
EPiServer 7
public virtual Url NewsImage{get;set;}
EPiServer 7.5
public virtual ContentReference NewsImage {get;set;}
all works fine if i were to to create anew project and start out with newsImage as a contentlink but this site has been upgraded to 7.5 from 7. how to I new make NEwsImage a contentreference when all other references in 7 were Url. Will this not break?
I would be interested in entertaining your thoughts or ideas.
