Can't create media or block Folders (store error?)
I just upgraded 7.0 -> 7.6 (the latest dll's) and got my site up'n running.
But I have a MAJOR issue with block and media folders, seems that I can't create a new one. If I try, then the REST call to http://mysite.com/episerver/cms/Stores/contentdata/ will fail with exception:
[ArgumentException: An item with the same key has already been added.]
System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add) +14648971
System.Linq.Enumerable.ToDictionary(IEnumerable`1 source, Func`2 keySelector, Func`2 elementSelector, IEqualityComparer`1 comparer) +267
EPiServer.Cms.Shell.Json.ContentDataStoreModelConverter.GetContentType(String typeIdentifier) +392
EPiServer.Cms.Shell.Json.ContentDataStoreModelConverter.ReadJson(JsonReader reader, Type objectType, Object existingValue, JsonSerializer serializer) +219
Newtonsoft.Json.Serialization.JsonSerializerInternalReader.DeserializeConvertable(JsonConverter converter, JsonReader reader, Type objectType, Object existingValue) +402
Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent) +790
Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType) +792
EPiServer.Shell.Services.Rest.RestControllerActionInvoker.TryGetParameterValueFromRestProviders(ControllerContext controllerContext, ParameterDescriptor parameterDescriptor, Object& value) +284
EPiServer.Shell.Services.Rest.RestControllerActionInvoker.GetParameterValue(ControllerContext controllerContext, ParameterDescriptor parameterDescriptor) +44
System.Web.Mvc.ControllerActionInvoker.GetParameterValues(ControllerContext controllerContext, ActionDescriptor actionDescriptor) +153
System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +720
EPiServer.Shell.Services.Rest.RestControllerBase.ExecuteCore() +301
System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +305
EPiServer.Shell.Services.Rest.RestHttpHandler.ProcessRequest(HttpContextBase httpContext) +274
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +913
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +165
Has anyone idea what the duplicate entry might be?
#85177
Apr 16, 2014 15:18
Also, I constantly receive following warnings to my Console.
Received message of type object from http://mysite.com, expected a string all.js:53
#85178
Apr 16, 2014 15:20
Ok, the error is because database has duplicate Block Type definitions. The duplicates are identical, even the GUID is the same, but they have a different TypeID. The blockType is defined only in one class.
How is this possible?
#85184
Edited, Apr 16, 2014 16:02
Hi Jouni
I am having the exact same issue. I have tow blocks types with the same GUID and Content Type Name but different Content TypeID. How did you manage to resolve this.
#109720
Oct 13, 2014 16:11
Hi Sayeed,
Try commenting out the whole duplicate ContentType definition in your code and restart the app. If memory serves, Episerver removed the invalid BlockType itself during startup. If not, try removing it by yourself. It should be possible now that it's not present in code.
#109728
Oct 13, 2014 18:01
Hi Jouni
I tried that. Whenever, I comment out the code for my Block Type, I get this error:
The DELETE statement conflicted with the REFERENCE constraint "FK_tblContentProperty_tblPropertyDefinition". The conflict occurred in database "dbLogicalisWebsite", table "dbo.tblContentProperty", column 'fkPropertyDefinitionID'.
#109729
Oct 13, 2014 18:05
I guess that's because there are existing blocks of the dupicate BlockType. Can you delete them in anyway?
#109744
Oct 14, 2014 10:28
I had the same error & I deleted the content in the tables that I get the error & it solved the problem.
#117224
Feb 13, 2015 22:04
