Setting appData basePath programmatically
Hi, I'm using a IConfigurableModule to override appsettings and connectionstrings.
Can anyone give som hints regarding setting the appData basePath in EPiServerFramework.config programmatically?
<appData basePath="SomePath\To\Some\Folder" />
#82688
Mar 18, 2014 11:24
Hello Rikard,
You can set it here:
EPiServer.Framework.Configuration.EPiServerFrameworkSection.Instance.AppData.BasePath
#82708
Mar 18, 2014 14:07
