Scheduled Jobs
Some question about scheduled jobs:
1. Is it possible to trigger scheduled job from code (programatically)?
2. Is it possible to track whether specific job is running at the moment.
#82937
Mar 21, 2014 14:34
1) You can trigger your job by following code (you need to obtain job Id for that - see point 2):
ScheduledJob jobInstance;
if (job.InstanceId != Guid.Empty)
    jobInstance = ScheduledJob.Load(job.InstanceId);
else
    jobInstance = new ScheduledJob
                              IntervalType = ScheduledIntervalType.Days,
                              IsEnabled = false,
                              Name = job.Name,
                              MethodName = "Execute",
                              TypeName = job.TypeName,
                              AssemblyName = job.AssemblyName,
                              IsStaticMethod = true
    if (jobInstance.NextExecution == DateTime.MinValue)
        jobInstance.NextExecution = DateTime.Today;
    jobInstance.Save();
if (jobInstance != null)
    jobInstance.ExecuteManually();
2) For checking whether job is running - you have to get job Id somehow.
var isRunning = EPiServer.DataAbstraction.ScheduledJob.IsJobRunning(job.ID);
To get job id you need to know type and probably assembly as well (to avoid collisions):
var job = ScheduledJob.List().FirstOrDefault(j => j.TypeName == typeof(YourJobTypeName) && j.AssemblyName == "YourAssemblyName");
#82941
Mar 21, 2014 15:25
You have to create new ScheduledJob instances for `jobs` (or actually `plugins`) that has not been executed yet - therefore -> there is no job instance generated for those ones.
#82948
Mar 21, 2014 17:45
You can check some sample code here: https://github.com/valdisiljuconoks/TechFellow.ScheduledJobOverview
#82949
Mar 21, 2014 17:45
