Partial Routing {action} is ignored
Does partial routing supports {action} segment?
I did following:
public class SearchPagePartialRouter : IPartialRouter<PageData, SearchPage>
        public object RoutePartial(PageData content, SegmentContext segmentContext)
            if (ContentReference.StartPage == content.ContentLink)
                var segment = segmentContext.GetNextValue(segmentContext.RemainingPath);
                if (string.Equals("search", segment.Next))
                    segmentContext.RemainingPath = segment.Remaining;
                    return new SearchPage();//that is my non-cms content
            return null;
public class SearchPageController : Controller, IRenderTemplate<SearchPage>
        public ViewResult Index()
           //I have this action executed by url http://<host>/en/search/
        public ViewResult Second()
           //I have 404 response by accessing url http;//<host>/en/search/second
My url does match following "default" route: {language}/{node}/{partial}/{action}.
But if I try to run
http://<hostname>/en/search/second
{node} = start page
{partial} = search
{action} = second
I have 404 response/
Why {action} segment is ignored for my partial route?
#82127
Mar 05, 2014 17:39
Just to clarify SearchPage is my custom object, not a cms page.
#82132
Mar 05, 2014 18:19
Looks like problem is inside ExistingActionRouteConstraint constraint.
Reflected code:
public virtual bool Match(Route route, SegmentContext routingContext, string parameterName)
    IContent content;
    string str = routingContext.RouteData.Values["action"] as string;
    if (string.IsNullOrEmpty(str))
        return true;
    if (!this._mapContentRouteParameters.ContentLoader.TryGet<IContent>(routingContext.RoutedContentLink, LanguageSelector.MasterLanguage(), out content))
        return false;
    TemplateModel model = this._mapContentRouteParameters.TemplateResolver.Resolve(HttpContext.Current.ContextBaseOrNull(), content, TemplateTypeCategories.MvcController, routingContext.ContextMode);
    if ((model != null) && (model.TemplateType != null))
        return this._actions.GetControllerActions(model.TemplateType).Contains(str);
    string a = (route.Defaults[RoutingConstants.ActionKey] as string) ?? "index";
    return string.Equals(a, str, StringComparison.OrdinalIgnoreCase);
It does action lookup not on actual routed data, but on "parent" content.
Is it a valid behaviour?
#82134
Mar 05, 2014 19:29
If I add "second" (with same name) STUB action on "parent" cms-content controller, it starts working:)
Looks like a bug.
#82135
Edited, Mar 05, 2014 19:36
Here is workaroung I've found:
    public class Global : EPiServer.Global
        protected override void RegisterRoutes(RouteCollection routes)
            base.RegisterRoutes(routes);
            //go through content routes and apply constraint fix
            FixExistingActionConstraint(routes);
        private static void FixExistingActionConstraint(RouteCollection routes)
            foreach (var route in routes)
                var contentRoute = route as ContentRoute;
                if (contentRoute != null && contentRoute.Constraints.ContainsKey(RoutingConstants.ActionKey))
                    var original = contentRoute.Constraints[RoutingConstants.ActionKey] as ExistingActionRouteConstraint;
                    if (original != null)
                        //replace constraint with custom wrapper
                        contentRoute.Constraints[RoutingConstants.ActionKey] = new ExistingActionRouteConstraintWrapper(original);
    public class ExistingActionRouteConstraintWrapper : IContentRouteConstraint
        private readonly ExistingActionRouteConstraint original;
        public ExistingActionRouteConstraintWrapper(ExistingActionRouteConstraint original)
            this.original = original;
        public bool Match(Route route, SegmentContext segmentContext, string parameterName)
            //try to minify "fix" influence and process only "my" partials routes (objects are marked with IVirtualPage interface)
            if (segmentContext.RoutedObject is IVirtualPage)
                return true;
            return original.Match(route, segmentContext, parameterName);
Does it make sense? Any pitfalls?
#82139
Mar 05, 2014 21:03
Hi and thanks for the detailed explanation!
I agree that this should be considered a bug. That is if a partial router has routed to something the validation should be against that controller (if any) and not the "original" cms content.
I have reported a bug for this.
#82170
Mar 06, 2014 11:26
Fixed in 7.6.5, release note: http://world.episerver.com/Documentation/Release-Notes/ReleaseNote/?releaseNoteId=112923
#85183
Apr 16, 2014 16:01
