Model binding not working in add-on
I am writing a custom episerver plugin with MVC and Razor.
I have a Controller, decorated with a GuiPlugin attribute. I have a Index, Delete and Create action. The index action is rendered correctly when I browse to it in EPiServer. However, when I want for example call the Delete action I want to add a id as routevalue. Somehow the id is null when I use it in the parameters of my Delete action. Apparently the modelbinding is not working correctly.
Should I build a new modelbinder for this or is my configuration faulty? I am hoping for the last option.
Model.config:
<module loadLocalBin="false">
    <assemblies>
        <add assembly="eFocus.Poliservice.Framework.Websites.Poliservice" />
    </assemblies>
    <routes>
        <route url="{moduleArea}/{controller}/{action}">
            <defaults>
                <add key="moduleArea" value="eFocus.Poliservice.Framework.Websites.Poliservice" />
                <add key="controller" value="" />
                <add key="action" value="Index" />
            </defaults>
        </route>
    </routes>
</module>
My Controller:
    [GuiPlugIn(
        Area = PlugInArea.AdminMenu,
        SortIndex = 1,
        UrlFromModuleFolder = "AccountsPlugin",
        DisplayName = "Manage website accounts",
        RequiredAccess = AccessLevel.Administer)]
    public class AccountsPluginController : Controller
        private readonly IAccountManager accountManager;
        public AccountsPluginController()
            accountManager = PlatformContext.Current.Container.Resolve<IAccountManager>();
        public ActionResult Index(int? page)
            var pageNumber = page ?? 1;
            int totalUsers;
            IPagedList<MembershipUser> users = this.accountManager.GetAllAccounts(out totalUsers).ToPagedList(pageNumber, 25);
            return View(users);
        public ActionResult Delete(string id)
            //do stuff
            return RedirectToActionPermanent("Index");
        public ActionResult Create()
            return View();
#82932
Mar 21, 2014 14:21
ActionLink:
@Html.ActionLink("Delete", "Delete", "AccountsPlugin", new { id = item.UserId })
#82933
Edited, Mar 21, 2014 14:23
Ok, i found the solution:
@Html.ActionLink("Delete", "Delete", "AccountsPlugin", new { id = item.AnvaId }, null)
and of course you must define it in your route. Not in routeconfig but in module.config:
        <route url="{moduleArea}/{controller}/{action}/{id}">
            <defaults>
                <add key="id" value="" />
            </defaults>
        </route>
#82943
Mar 21, 2014 16:29
