Localized Editor
I'm trying to get a localized editor going, but it doesn't seem to work.
I've tried following this blogpost, but I get no result going. I've also registered a provider as seen in this XML-segment:
<episerver.framework>
  <localization fallbackBehavior="Echo, MissingMessage, FallbackCulture" fallbackCulture="no">
    <providers>
      <add virtualPath="~/Resources/LanguageFiles" name="languageFiles" type="EPiServer.Framework.Localization.XmlResources.FileXmlLocalizationProvider, EPiServer.Framework" />
    </providers>
  </localization>
This is my language file:
<language name="Norsk" id="no">
  <pagetypes>
    <pagetype name="ActivityPage">
      <description>Inneholder informasjon om en aktivitet.</description>
      <name>TEST</name>
  </pagetype>
</pagetypes>
Is there any documentation around this?
// Anders
#82325
Mar 11, 2014 7:57
Per Nergård (MVP)
The xml structure is different for 7.5. See Linus blogpost for more info:
http://world.episerver.com/Blogs/Linus-Ekstrom/Dates/2013/12/New-standardized-format-for-content-type-localizations/
#82327
Mar 11, 2014 8:13
Thanks, Per!
That worked beautifully!
EDIT: One thing I noticed is that «name» and «description» of the page type didn't work at all. It uses the name of the class and it says that no description is available.
#82339
Edited, Mar 11, 2014 9:39
I followed Linus' post and the «name» and «description» doesn't work for me. This is my XML:
  <!-- Page Types -->
  <contenttypes>
    <activitypage>
      <name>Aktivitet</name>
    </activitypage>
  </contenttypes>
</language>
I also have properties inside the different page type elements and those works pretty good.
What am I doing wrong?
#82417
Mar 12, 2014 7:51
The xml looks correct. Could it be a fallback issue? Do you have norwegian set as the current episerver user's personal languge?
#82427
Mar 12, 2014 9:23
Thanks, now it works. I thought it was based on which language you were editing in, not the user's current language. It all makes sense. Thanks for your quick reply, Per Magne.
#82428
Mar 12, 2014 9:39
