Extra Divs in ContentArea
I have the following ContentArea Propety on my page:
        [CultureSpecific]
        [Editable(true)]
        [Display(
            Name = "Main Content",
            Order = 10)]
        public virtual ContentArea MainContent { get; set; }
And in my template file, I have
@Html.PropertyFor(x => x.MainContent)
To output the blocks..
What's really strange is I am getting a <div><div> (double divs) wrapping any of the blocks that are added.. I have no idea where these are coming from.
Can anyone suggest anything please?
Danny
#82128
Mar 05, 2014 18:05
It appears that it wraps all items in an outer div, and each item in it's own div (hence opening and closing double divs?)
Looks like it's answered in http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=69955
My issue is it's adding the extra mark up for my <ul> lists:
so, I have
<ul>
    <!-- start block items -->
    <div>
        <!--block -->
        <div>
            <li>{content}</li>
        </div>
        <!--end block>
        <!--block -->
        <div>
            <li>{content</li>
        </div>
        <!--end block>-->
        <!-- end block items -->
    </div>
</ul>
I'd prefer the extra divs removed, but I can see if the css dev cna update his css to display content correctly in that format
#82130
Edited, Mar 05, 2014 18:08
You should be able to use customtag and childrentag for this.
@Html.PropertyFor(x => x.Rotator,
    new
            ChildrenCustomTagName ="li",
            ChildrenCssClass = "rotator-item"
#82136
Mar 05, 2014 20:25
You could always create a custom content area that doesn't render the divs in live mode  If you only need to do this once or twice on your project then it's a bit overkill and I would go with the usin gthe ChildrenCustomTagName.  I fyou are interested in how to remove the div's via a custom content area I  wrote a blog post about it Extra divs in content area how to remove them ?
#131872
Aug 07, 2015 12:07
