Upgrade is always interesting cases. EPiServer packages are sticked with particular version of dependnecy I guess just because to be "on-safe" side - framework is tested with that version of library and upgrade is explicitly on your own risk.
But I agree - that logging should be unified. I guess that's just a historical heritage.
What we usually are doing is to unify CMS and Commerce logging by specifying that Common.Logging adapter is log4net and config source is EPiServerLog.config (in web.config):
<common>
<logging>
<factoryAdapter type="Common.Logging.Log4Net.Log4NetLoggerFactoryAdapter, Common.Logging.Log4Net">
<arg key="configType" value="FILE" />
<arg key="configFile" value="~/EPiServerLog.config" />
</factoryAdapter>
</logging>
</common>
Some questions:
1) Cms uses log4net as logging subsystem. Commerce uses Common.Logging as logging solution. Is it planned to unify this and end up with single one (Common.Logging I suppose as more generic solution) ?
2) Does it planned to update references in commerce nuget packages packages. Common.Logging < 2.0 dependency looks outdated. Atleast Common.Loggin 2.1 is fully backward compatible with 1.2 version but has usefull features like lambda expression:
log.Debug( m => m("value= {0}", obj.Value) );
